RE: Switch settings for 12FG
You can also assign the throttle trim to a slider or whatever you want if that is your preference. I use the slider on the upper left corner of my 14MZ for throttle trim on my planes and helis.
I use the spring loaded switch to turn my timer on and off like a stopwatch. I have also used it for the throttle cut feature.
