RE: Introducing the Italian Battle Unit (I.B.U.)...New videos
So as to my original question is there answer? ? As with the elmode, will you be offering a way to make adjustments to how the tank may run turn stop using the many styles of gear systems available such as Asiatam's 321, tamiya gears, plastic gears etc. by offering the use of a configuration cable and the configurator. Also what will the maximum voltage usage and what type of weight will it be able to handle. will it run well with weight and the use of metal tracks? Your system sounds very well thought out and it will bring more excitement into this hobby, and I am looking forward to seeing this happen. It will definitely bring a lot more tanks to the battle field that were unable to battle each other. Thanks for your hard work all involved.
