ORIGINAL: ezcruz13
for wide open, how do keep your .27 cool enough to get through a full tank. i know thoses engines run very hot, but dam they keep over heating and shuting off, and if i go any richer ill bog the dam thing out. any thoughts?
Sounds like your piston and sleeve is worn. When that happens, the sleeve expands when the engine heats up, and the engine loses compression and will just die and wont start back until it has cooled off. A new piston and sleeve, a repinch, or a new engine all together would be the fix for that.
Eric
