Odd Carb Problem= DLE 30 side carb
My DLE 30 side carb will not slow down to a reasonable idle. am sure it is not in the linkage as I unhooked the linkage and moved the arm on the throttle to its full idle. It is still running about 2500 or more. The brass flapper on the throttle arm can be seen closed all the way and the engine just keeps running. The aceleration is perfect, the high end is right up there. Just it will not slow down to an usable idle. Any idea's or suggestions. I repeat I pushed the throttle all the way closed while running and it just keeps going. Stuka Jon
