RCU Forums - View Single Post - Leaking Robart Valve
Old 04-15-2002 | 03:06 PM
ECalderon's Avatar
ECalderon
Default Leaking Robart Valve
I have a leaking problem in both my Blue Robart Valve. The first one when new holded pressure OK but after sitting unused for several months it started to leak. I thought I had a bad valve so I bought a new one and the same thing happened. :angry: After an hour or so there is not enough pressure to operate the gear.
I know the problem is in the valves because when I put them, installed in the airplane, inside a glass of water you can see bubbles escaping from it.
I have changed the O rings and lubed them with BVM O Lube to no avail.
Is there any way to fix this permanently, other than buying new valves each season?
I would appreciate any comments.
Eduardo
