ORIGINAL: yakfish
2200kv x 25.2v is 55440rpm. That might be enough to do what I want. most onroad nitro engines only pull 34000-40000rpm so 55440 would definently be an improvement.
I will need to find gears for it too. I don't know if it will be possible to keep the 2 speed setup or not either.
6S is 22.2, but its all about torque, you can gear the motor much harder cos it has a lot more torque.
