RE: F3A plans
No need to convert the files. they are in the proper form, you just have to rename the file extension. When you go to save it, Use "Save As" and where it says .txt in the name, rename it with .dwg so it will be called Attachment.dwg for the second file, and the third file will be renamed Attachment.dxf
