GP extra330L...any thoughts?
I built one, came out under 22lbs with ZDZ 80 26x10, flies well.
It is a totally built up plane which helps with the weight but requires a bit of work to build especially with the sheeted sides
which are then cut for the wing to slide in.
Under repair after a midair accident.
For the price it is not bad if you can build and have the time and no rush.
otherwise the price of ARF's are competitiveas mentioned above.
