RCU Forums - View Single Post - Model Tech CAP 21 (72 inch) HELP!!!
Old 08-17-2003 | 01:01 AM
mglavin
My Feedback: (31)
Default Model Tech CAP 21 (72 inch) HELP!!!
30% of the MAC will get you close to the desired CG.
Low rate travel should be around 15 degrees and high rate as much as you get, typically 50 degrees or so (kind of depends on your abilities, you can always program less and add more as you become accustomed to the model). Program some expotential for aileron and elevator, maybe 30%...
These Cap were well know to be snappy which is of course an atypical CAP thing! Keep up the speed on the landing...
