RE: GROUP BUILD - Top Flite Giant Scale F4U Corsair
Hey gang, well I layed the 1/64th chart tape for the panel lines in the fuse and man I don't know about you guys but the tape I recieved from Graftix sure didn't want to stick very well. I put 3 coats of primer over it and then pulled the tape. I've never done panel lines before so I'm not really
sure I know what the hell I'm doing. I tried leaving the tape on to begin with and sanded the primer but found I was also sanding the tape which made it rather difficult to remove after so I decided to just pull all the tape and do my sanding. I am going over the lines with a scribe as I go to save the lines.
I'f anyone has some good ideas on how to do this please chime in.
I don't know if there is a better tape out there that I should be using or what. I can't find any tape in Canada tht is 1/64th.
