RCU Forums - View Single Post - Sig 1/3 scale Spacewalker
Old 07-11-2011 | 12:03 PM
  #195
huck1199's Avatar
huck1199
Default RE: Sig 1/3 scale Spacewalker
Del
Nice looking plane. I hope my paint scheme looks as nice.
ZeroDave
Yes, the kit is still available from Sig.
Tom C
Made a little progress. I have been busy installing new windows in my house. Replaced 14 and have the big front picture window left to do. Then I have to put up the new siding - 22 sq.This is getting expensive. But here are some more pics.
1. Put in the cross member to hold the rudder pull-pull wires,
2. Mounted the horizontal stab and triangle stock on the underside.
3. Mounted the fuel tank and a removeable cross brace. I am using 5/32" tygon for the fuel feed and 1/8" for the vent and fill plumbing.
4. Trial mounted the engine, Turnigy 52cc, to determine throttle servo location. Flipped the carb over to make the throttle arm easier to hook up. I replaced the original arm with one from Jody as suggested - it is very nice.
5. Put on side blocks where the fuse sections are joined so that I can seam the coveriningaft of the cockpit. I will use one piece of matterial for the sides and top. Then use four pieces for the aft fuse - 1 top. 2 sides, and 1 bottom.
ID:	1633962   Click image for larger version
ID:	1633963   Click image for larger version
ID:	1633964   Click image for larger version
ID:	1633965   Click image for larger version
ID:	1633966   Click image for larger version
