RE: msr frame
you can superglue the peg back on and reinforce it with a carbon fiber stick glued across. i dod this on mine and it worked fine until the peg broke again in a different place lol.
the frame is not hard to replace.
step 1. remove canopy
2. pop off the 2 ball links on the swash
3. remove 5in1board and reinstall it on new frame
4. remove landing gear
5. remove large gear from shaft and remove the whole head/shaft. blade assembly from heli.
6. remove bearings and put them in new frame.
7.take the motor out and put it on the new frame.
8. remove tail boom and put it on new frame.
9. install the main shaft and rotor assembly onto new frame and put the spur gear on the end and pop the ball links back on the swash.
10. install landing gear and canopy and go fly your heli.
