RCU Forums - View Single Post - DLE222 Starter System - The Project
Old 07-11-2011 | 03:02 PM
aussiesteve's Avatar
aussiesteve
Default RE: DLE222 Starter System - The Project
Hi Umran
Great work mate.
Looking over the numbers you are coming up against, You may want to consider a Planetary reduction instead.
It will likely be more compact for the required ratio and the loads are shared across more than one tooth set hence the ability to use a smaller tooth.
