RCU Forums - View Single Post - Silver Swallow Pulldown
Old 07-11-2011 | 04:28 PM
  #31
123Cat
Default RE: Silver Swallow Pulldown
Saw an article comparing a Nascar engine to a F1 engine in 2006 the Cup eng does 10,000 RPM the F1 engine does 19,000 RPM, the rod to stroke ratio is 1.9/ 2.56 respectively
2.56 is a long rod
a 2.56 rod in a 2 stroke would mean you have to lift your cyl up about 9mm say in my 09, that would mean a lot more crankcase volume , is that a good thing in a small diesel ?
By the way the cup engine had a rod from a steel called 300M ( Modified 4340 , vacuum melted ), and the F1 engine had high grade titanium , I think its about 40% the weight of steel
Anyway I dont feel like running a short conrod anymore after looking at all the latest in models and high revving car engines , they all have long conrods ,
To space the cyl upwards on my silver swallow is hardish , but I may give it a try ,
and also the cylinder is not located very well in respect of the bottom end so that is another thing ,
I could check to see if it is square with the crank axis
<br type="_moz" />
