ORIGINAL: rt3232
Phil
Hate to see you mess up the out side of your bird, T/F designed the kit to work and in most failures it is the builders falt, with that said I would do what I suggested in post # 8045 and above on this page. If you are going to get into her you might as well go with covered hinges more scale like, as you have to much invested to not ID the problem and fix it at the root.
Cutting the hings and pulling the pines is not hard just tedious, just an old mans 2 pennys worth
Cheers Bob T
Thanks Bob. I really neecd to put her under the microscope before I make any real decisions. I hope i get the chance to do just that tonight...
