RCU Forums - View Single Post - OS 61SF Idle Problems
Old 07-12-2011 | 04:49 PM
JRgraham
Default RE: OS 61SF Idle Problems
ORIGINAL: tony0707
HI
all due respect -, you bearing wear is very extreme you should ...
BEST REGARDS TONY
Yeah, it was extreme Ithink too. I'm sure some was how we ran the engines, but O.S. replacement bearings were just fair quality too. There use to be a nice aftermarket replacement for those motors back in the 90's that would last longer, and was real smooth.
Also we ran tuned pipes almost always on them.
There is also a difference not mentioned yet here with this motor group/erra, some had ABC piston/sleeves, where others had the standard nickle whatever. Though not anything related to a fuel issue..
Ican tell you though, we were not the only people that 'were hard on' bearings.
Yeah, id try running it with a stock backplate too, with muffler pressure. cant hurt while your waiting for parts.
