RCU Forums - View Single Post - Binding w/Opto Kill Switch
Old 07-14-2011 | 06:40 AM
Rafael23cc's Avatar
Rafael23cc
Default RE: Binding w/Opto Kill Switch
ORIGINAL: scale only 4 me
....I guess the only potential down side is if you swap RX with an already bound RX for some reason, you have to remember to re-set your failsafes,, with futaba the TX tells the RX what to do constantly or on power up?? Both systems work fine I guess
If you swap a receiver without making sure all the settings are correct, including re-binding to the radio, you deserve the results, no matter what manufacturer you use.
Rafael
