Balancing Props
The easy way to balance is to not sand at all. Instead, rub a small amount of 5-min.epoxy on the back of the light end of the prop. You'll be surprised at how fast you will have a perfectly balanced prop. After the epoxy has cured, dull it down with fine steel wool and you won't even be able to see it. Try this once and you will never sand another prop again............Jerry
