RCU Forums - View Single Post - Binding w/Opto Kill Switch
Old 07-14-2011 | 05:13 PM
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Default RE: Binding w/Opto Kill Switch
ORIGINAL: Rafael23cc
ORIGINAL: scale only 4 me
....I guess the only potential down side is if you swap RX with an already bound RX for some reason, you have to remember to re-set your failsafes,, with futaba the TX tells the RX what to do constantly or on power up?? Both systems work fine I guess
If you swap a receiver without making sure all the settings are correct, including re-binding to the radio, you deserve the results, no matter what manufacturer you use.
Rafael
How would swapping RXs affect anything,, the TX is where all the setting are stored,,, except apparently the Fail Safe in the JRs
