RCU Forums - View Single Post - Goose's Aeroworks ProX260 build thread
Old 07-14-2011 | 06:01 PM
v6goose's Avatar
v6goose
Default RE: Goose's Aeroworks ProX260 build thread
Well... I really thought my luck had changed on this one, but it seems not.
Everything went so well up to and including the [link=http://www.youtube.com/watch?v=5x8PqgGGFGg&feature=youtube_gdata]engines first run-up[/link].
Then while defueling... *click*
Guess what that was ?
Fuel nipple broke off the carb.
Awesome. ONE day left until I am on holiday for two weeks with a new plane and f(*&^%ing Murphy steps in.
Yes, it was my fault but come on... gimme a break!
The DLE has a Walbro knock-off carb and feeds fuel in through the side of the carb housing which is different from my DL-50 and the fuel nipples are different sizes (of course).
I removed the remaining black plastic to find a brass or bronze press-fit fitting that sticks out just a couple of mm. I have some brass tube that fits well into the hole but can't braze it in there.
I think my only options now are to:
[ul][*] Replace the fitting ex overseas god knows how long that will take if you can even find a supplier.[*] Replace the whole carb. Better option except for cost and LHS doesn't stock carbs.[*] Destroy the press fitting to get it out, tap the hole and screw in a standard fuel nipple.
[/ul]
Option 3 makes most sense right now I guess. I'll have to source parts tomorrow but have to sleep now because I'm so angry [:@]
G
