RE: Extreme Flight 88
Thats because he more than likely did not open up the cooling area down below, I cut out a 'square' hole on the bottom flat area so air goes straight through as well as original air duct facing rearwards. Without the area cut out to aid air flow the engine could overheat, my DLE 55 has performed 100% with the extra area cut out. It works!!!
Alan
