Traxxas Spartan ESC problems? HELP!
I just purchased Traxxas Spartan boat and it has a Tacon 1700 motor with a SeaKing 180 ESC and I also just purchased new Venom Lipo 3S 5000 35C batteries.
Initial run seemed to work great but I did submarine it. Ran fine for about 4 minutes after that. Next time out ran the boat and it was acting weird so I brought it in and smoke was coming out of it. Found the collet came loose and was slipping on the cable and got really hot! Tightened it back up and then the boat would only run for about 10-45 seconds before shutting down. When I run it dry, it will run for a couple of seconds then the motor abruptly stops. You can turn the motor by hand so I know its not locked up. The ESC does display a solid red light when this happens. If I unplug and plug the batteries, it resets it and it will run for a little bit longer then lock up.
So did I get the ESC wet and its action up or is it getting to hot within 30 seconds of running it. I do need to rework the cooling system as just a slow trickle of water is coming out the side at speed. The previous owner did the rudder mod with larger tubing and dual outlets, but I think the wimpy y-connector coming from the rudder is way to restrictive and needs to be replaced with a higher flowing unit.
Any ideas?
Doc
