RE: Traxxas Spartan ESC problems? HELP!
is it the stock flex cable or is it some1 made for the setup? the seaking should be pretty water tight the y connector helps but it really should have 2 seperate cooling lines 1 for each component. the stock traxxas flex cable is JUNK! i know some1 that can make u a cable for 28 bucks im running 1 in my deuce and its working flawlessly.
