RE: Does gyro on rudder work against aileron?
It's you who is confused John. If you read my post it is quite clear I gave a very powerful differentiation between rate of turn and yaw rate, showing how yaw rate can fall close to zero in the tightest of turns. Your claims about balanced turns are about a totally different thing since it involves the balance between centripetal and gravitational acceleration.
H
