ORIGINAL: rccrasher65
Robert, how many of the upgrades did you use in your plane. The guys are now discussing the wing tip. I think I'm going to stay with the original plans. I don't want to alter the plane that much. did you follow the plans or did you change alot. I have the short manuel and the long version for reference. George
George,
We have Dan working to make his wing more scale. You are aware that the spars are in the wrong location on the kit are you not? Actually redoing the wing makes a lot of things (strut mounts etc) work out better. It also slims down the wing quite a bit. Makes it a ton stronger as well.
Bill, Waco Brother #1
