RE: beginner
Hobbyzone recently decided to install the 2.4ghz system in the existing Super Cub Trainer. It's a great airplane that up until recently was only available in 26.995mhz. Bad choice for frequency selection on the manufacturer since this is right in the range of the CB radio (our field is right next to the county truck yard which has many trucks with CB radios installed). Long story short I got hit and lost control, but it wasn't a crash. Airplane came down and landed, but I couldn't turn off the throttle. As a result ended up with a burned out ESC. Called Hobbyzone and asked about conversion to a 2.4ghz system, and was told that I would have to purchase a new aircraft since they do not offer a conversion for the older 26.995. New price for the 2.4Ghz - about $199.00. Horse Feathers on that!
Conversion by yourself is very simple, here's how I did it.
Purchased the following from Graves Hobby in Orlando, FL (I was down there to see the last Shuttle launch)
(2) two Hitec HS-55 servos. Cost - $7.99 each.
(1) one BPA2217-9 Brushless Motor. Much better and more power than that cheap brushed geared unit the model comes with. Cost - $20.95
(1) one Thunderbird CSETB18 Brushless Speed Control (ESC). Cost - $33.99
(1) one Futaba 6 Channel 2.4GHz FASST Park Flyer Receiver. Small and light in size. Cost $59.99
(1) one ACP 9 x 6 Slow Flyer Prop. Cost $2.99
<u>Total Cost $133.90</u>
Might seem a little expensive with the receiver cost, but my others are for larger aircraft. <u>The larger receiver units probably will work also so I could have saved the $59.99 which would have put the cost down to $73.91.</u>
Procedure - Removed the original receiver, ESC, servos, and electric motor that came with the Cub from Hobbyzone. Installed the two (2) Hitec H55 Servos in the original location of the older servos by gluing them in place with Shoegoo Shoe cement from Walmart. Installed the ESC per Thunderbird's instructions (very simple with small amount of soldering). Used the original 3 cell 11.1 1300mah Lipo battery along with the plug from the old 26.995 receiver(soldered to the new ESC). The most time consuming task was removing the original motor mount and modifying it for the new brushless motor. For this I removed the prop shaft and brushed motor from the mount, <u>then</u> I cut the prop extension and holder for the original motor off using a band saw. This gave me a flat portion of the mount from which I attached a cutout piece of 1/16" ply to attach to brushless motor to. The original mount along with the brushless motor puts the prop in about the same location as with the original configuration. Lastly I needed to trim the prop hole in the cowling slightly with my Dremel tool with a sanding drum for adequate clearance.
Fly's like a dream with much more power, and now I've got 2.4Ghz..
