RCU Forums - View Single Post - FEJ Viper Build
Old 07-18-2011 | 02:24 PM
  #55
FMRR
Default RE: FEJ Viper Build
ORIGINAL: enrico63
Hello , I use self sealing festo valve to connect and disconnect the hydraulic system between the wings and the fusolage. If you don't want to use the Festo valve you can try specific valves produced by Eurokit in Lucca. Best regards
Hi enrico63,
Are these zero loss disconnects so you don't have to bleed the system everytime you remove the wing?
