RCU Forums - View Single Post - CAP 232 on li-poly
Old 08-17-2003 | 12:27 PM
mattijs
Default CAP 232 on li-poly
My main problem actually is that i don't want to pay more for the cap if it turns out it can't be flown AND prop hanged on li poly's like simple EPP foamies do like the cobra and the eagle....eventough both just have a brushed motor and the suggested setup for the cap is a brushless.
Maybe i should just go for the durability and low cost of the foamies but this little cap looks so good.
I have never flown electric and li-poly technology finally made electic appealing to me. I really like the idea of flying several 5 minute flights on one charge wothout the need for trickle charging.
Also, when coupling several li poly's in parallel...doesn't that implicate the need for longer charge times? Or do you normally take the risk of charging them parallel with the danger of rendering a pack unbalanced?
My ideal would be one hour charging , 20 minutes flying. Is that possible on ANY of the higher performance electrics, foamie or fiberglass fuselage????
ALOT of questions , again i am new to electrics but it sure looks more interesting then say 2 years ago.
