ORIGINAL: kerwin50
The DLE carb has a natural mid range burble, There is a mod you can do to the carb and the capt'n did it to his over at the DLE thread. Me I'm just living with it.
Now I know it's not the best 3d prop but I'm using the APC 18/6W an I've had a few ground strikes. Before I was using the XOAR props but after breaking 2 of them I went to the APC
This is more than a mid-range burble...Jody suggested that I check the spark plug gap and set it to .024. I will try that this weekend and see how it goes.
Also, I put on a black Xoar prop and I think it makes the plane look much nicer than the wood prop; I've attached a few pics for your enjoyment.
-Mike
