RCU Forums - View Single Post - Engine Help
Thread: Engine Help
Old 07-19-2011 | 05:27 PM
volksman
Default RE: Engine Help
the pulse hole in the carb or block may have some material flash in it, pump not in right. most will not draw fuel until engine fires. but once it starts should be away. if it has a set of reeds under the carb check they are seated no tears etc. walboro is sorta simple but pluged or no pulse no work
