RCU Forums - View Single Post - Flutter in servos
Old 07-20-2011 | 06:32 AM
Rodney
Default RE: Flutter in servos
Sounds like a bad connection or two. Do you have any extensions on the servo leads? If so, that is often a problem if they do not get disconnected and reconnected occasionally to remove any oxidation or corrosion that occurs in the connectors.
