RE: Skymaster Mig29 with P200
Great Anton, thats helps. Looks like the turbine was mounted too high in Dantley's plane, will have to fix that. Also we were having problems with the pipe fitting properly, it does not seem to want to sit low enough without being smashed on the bottom of the fuse. It is also hitting the stab horns in the rear Anton, what do you think?
