RCU Forums - View Single Post - Kangaroo - split elevons or sep. Elev and Ail????
Old 07-20-2011 | 01:22 PM
  #34
phantom_najd
Default RE: Kangaroo - split elevons or sep. Elev and Ail????
ORIGINAL: Crazy4Flight
you may want to add canards to your Roo. Then it will fly much like the Rookie II. No more delta wing tuck!
you can order rookie II parts and make your own mount
Well, that sounds like a nice and a bit easy modification to think about. The roo sure have enough space in the fuse for that mod. I guess the CG will go further front with the canards. Thanks for the tip I sure will look into it.
Azzam
