RCU Forums - View Single Post - GP Aeromaster Kit Build
Old 07-20-2011 | 02:52 PM
  #45
rickbrad
My Feedback: (30)
Default RE: GP Aeromaster Kit Build
Well, as Isaid above in the text, I finished the bottom wing a week or so ago.
Here is one of the typical wingtip details. There is not too much to doing these other than trying to make sure the 1/8" balsa wingtip itself gets glued onto the outer rib at a 90 deg angle. After that, it is cutting some 1/4" stock at angles, sanding them to fit, and then sheeting. This example tip is only shaped with 80 grit; Inormally wait until right before covering to go over the model with 120/180:
I did encounter this one problem wingtip that when Iput on sheeting it dimpled in.That is certainly one of the drawbacks to CA, you only get one chance. Idon't know if Iam going to fill it or rip it off:
