ORIGINAL: Pylonracr
Why???
Use CA for balsa, and epoxy for hard wood. 6min epoxy is good for gluing on tails and stuff where you need a little time to align. 45 Minute epoxy for any structural hardwood or aircraft plywood.
It has always worked in the past, so if it ain't broke dont fix it.
Pretty silly statement, CA is the new kid on the block. I'm a CA user but I am on the last stage of sanding on a fully sheeted plane at the moment and have been reminded why I often sheet with wood glue. Any CA on the outside of a seam is like sanding steel. Next time I will sheet or at least glue my sheeting with wood glue. All glues have a place in model building, any builder that has been doing it for a while will have several types of glues on there bench and not limit themselves. I also don't just listen to one type of music, that would be limiting myself and just a very stupid thing to do.
