RCU Forums - View Single Post - Priming with ether is not strictly neccesary..
Old 07-21-2011 | 10:12 PM
Motorboy's Avatar
Motorboy
Default RE: Priming with ether is not strictly neccesary..
ORIGINAL: 123Cat
Darn , you cant run castor with gasoline , I need castor in Controline
Im rough with motors and need the extra protection
When my engine ran at motoroil, there is still motoroil out of exhaust. Not burned together with kerosene/gasoline. When i mixed the kerosene and castor oil, it can not mix, then i added a bit Klotz Benol castor oil, it will mix castor oil and kerosene togheter. Next time i will take a test with castor oil in kerosene/gasoline fuel and take a movie of the engine running with castor oil.
And gasoline is not so dry as methanol or ether there is still lubrication properties in gasoline. Nothing to be worried
