RE: multiple throttle servo failures
I have been using nylon rod to connect the throttle servo to control arm on the gas engines. The servos are standard futaba ones with Nylon gears. Never have a throttle servo failure.
I think the nylon rod isolates the vibrations well. To prevent the bending, a sleeve tube is added for the rod to pass through.
