RE: Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
Those fronts are terrifyingly thin I think there going to be more of a hassle than benifit take at least a thicker set of tires on your run day, lemme ask you why do you stick with so much heavy steal if you obvesly have access to machining tools youncould have built the whole car from a carbon fiber chassis and carbon fiber upper deck the whole way thru???? You would have has 1/4 the weight and twice the stiffness...... I see the chassis flex being a huge issue here......
Make sure you get 2 real passes this time with the car not that one BS pass you did with the rocket car
