RE: Newbie here
When you turn the airplane around and it starts to come toward you with one wing low. First don,t start blipping eveything like a vidio game just relax and move the stick under the wing that is low!
You don,t even need to think about left or right simply move that little stick under the low wing as if you trying to prop it up. And it does not matter if you using ailerons or a rudder for control or which mode you may be using.
John
