ORIGINAL: Recycled Flyer
''Can you tell to me since i am deaf man about there is still ''knocking'' in the engine?''
Honestly, the engine does sound to me like its gone 'hard' or over the top with compression and the last movie shows rather dark oil - an indicator at times of too much compression.
The weird intermittent 'knock' sound seems to be still there but don't trust just one opinion gained from over the internet, I would like to hear from others here what they think also!
Thanks mate.<br type=''_moz''/>
I got message from AMB: sounds fine no static no hash no knocks sounds normal martin
When i tried to reduce compression, the engine will die... hence black oil in castor oil..
Note: in all fuel i maked without ether are IPN
not added who i can reduce ignition lagg and reduce compression a bit..
Next time i will take a test run with IPN added and see what i get in results..
