Why does my plane do this?
My own CAP was bought to use the 3.2 engine that I'd had on my Stinger. The stinger was really well behaved but couldn't do 3-d. No coupling, no wierd snaps. Well, it would snap out if I got the controls way crossed up during a hover. I had it balanced for neutral elevator upright and inverted. If I could just have solved the wing rock it would have been a great 3d plane too.
I'd read about the ideosyncracies the CAP has and figured I'd just take on each of them and work it out. However, when I found that the landing approach and flare limits where you can put the CG, I wasn't happy. I tried various thrust angles, etc to get the plane to behave on approach as well as in the air with no luck. It's very frustratinig to have a plane that will perform well in the air at a rear CG location, then you need to hold forward stick on approach for some reason. That's uncomfortable as well.
The snapping on mine was strange, in that it was like a micro-snap - it would steepen in a left turn or drop the left wing on final without going hard over, and I could correct with opposite aileron. Still not sure what was going on there.
Anyway, I think both the Extra and the Edge are designed with the thrust line, wing and stab close to the same line (like a Stinger) and without the weird stuff that the CAP does.
