RCU Forums - View Single Post - Escapade .40 a good second plane?
Old 07-26-2011 | 04:15 PM
GP23
Default RE: Escapade .40 a good second plane?
The small Escapade is a great plane, but I would echo what a few others mentioned about the quality of the build.  Unfortunately, that extends into areas that are covered (such as the rudder), so if you go that route please do an intergrity check on every inch...as you should with any plane really.
Another reasonable option for you is a Great Planes Super Sportster 40...a little pricier (about $45 more) but certainly a more popular model that seems to be in-line with your parameters.  I believe the Escapade might build a little faster, if that matters to you.  Just throwing something else out there....
Good luck in your search!
