RCU Forums - View Single Post - Escapade .40 a good second plane?
Old 07-27-2011 | 05:25 PM
DIVERHERB's Avatar
DIVERHERB
Default RE: Escapade .40 a good second plane?
I have flown my Escapade for about 6 months now and after a little trial and error love it. I enabled flaparons on my radio to slow it down a little on landings as it was a little fast. I also switched to a 11x4 acp prop which slowed it down even more on landing without hurting performance at all in fact I think it helped. I am using a 40 S.T. I have dialed in about 10% flaps that Iactuate on the final approach and this thing just kinda hangs in the air. I have had no trouble with the canopy at all. In fact I find that when you attach it properly it is pretty hard to get it loose. The only 2 things that I found on the plane to give me trouble was the tail wheel (very cheap and bends easily so I changed it to a dubro. And the CG on the instruction sheet is way off to make it fly good, so I moved it back until it felt comfortable. I would really recommend this plane for second plane, it is actually a lot of fun. I am thinking of getting the
escapade 60 now. By the way with the white wings it can be a little disorienting if you are not paying attention. Try on I think you will like it and you will also find the price hard to beat.
