RCU Forums - View Single Post - .60 size Pattern Tiporare Build
Old 07-29-2011 | 11:27 AM
  #163
Jim Clausen's Avatar
Jim Clausen
Default RE: .60 size Pattern Tiporare Build
I now have the pull pull setup for the rudder complete. I crossed the cables to get a better angle to the rudder clevis cletes. I did not have any 2-56 clevises that I wanted to use so they are on order. Because I did not have the clevis I have not completed the manufacturing of the pull pull cables. I want to make sure of the length before completing that task.
I started the task of putting on the hobby co wood filler on the lower part of the wing and one side of the fuselage. It is taking multiple coats which just takes time. I plan to sand out the bottom part of the wing then prime it before starting on the upper side. I am doing this because of how soft the wood filler is and thought it would protect the surfaces better if primed.
The elevator modification is almost complete, I just need to put a thin piece of ply on the area that I removed and sand it flush with the other surfaces.
Tomorrow is another very hot day here in Georgia.
Jim
