RCU Forums - View Single Post - Aileron differental
Old 07-29-2011 | 07:39 PM
mudboger07
Default RE: Aileron differental
I can understand that, I have always set up my planes withthe same amount of throw in both directions and used rudder if needed to hlep in turns but just resently desided to set it up per the manual, im just curious is how the plane with react with this set up? will the turns be some what the same? As stated earlyer Inorm set rates to max but im wanting to try to set this one up per the manual, witch says to set the alierons to move higher on the upside and less on the down side.
