RCU Forums - View Single Post - Sig Kadet Senior - Tail dragger conversion?
Old 07-30-2011 | 01:08 PM
repirazz's Avatar
repirazz
Default RE: Sig Kadet Senior - Tail dragger conversion?
ORIGINAL: SeamusG
Just a CG note. For every 1/4 oz. added at the tail you'll need to offset this with 1 oz. at the firewall.
Good note seamus, but also keep in mind the main gear will be removed from behind CG & relocated a few inches ahead of CG. Should compensate for added tailwheel & loss of nosewheel.
KMOT- you'll want to mount main gear so it's centered directly under (or close within reason) the leading edge of wing w/ plane level.
-Rep
