RCU Forums - View Single Post - NEXSTAR ARF .....PROBLEMS...PROBLEMS
Old 07-31-2011 | 05:38 AM
  #114
5anace
Default RE: NEXSTAR ARF .....PROBLEMS...PROBLEMS
<span style="color: #0000ff">Your problem is quite simply solved. If the aircraft won't taxi straight it can't possibly hope to take off straight. You simply recentre the rudder servo and adjust the clevise to centre the rudder.
My problem with the kit is that I can't get the blind bolt at the trailing edge of the wing to go into the blind nut. No how. No way.
</span>
