RE: New CDI - opensource project JMJ and Bigboat
Personal preferences for timing curves can be addressed to Nyemi. He has offered numerous times to accommodate requests.
Another project to be added in the near future is an inline tachometer, which simply plugs into the hall sensor cable with a Y-cable for testing your engines performance figures. If anyone has a tested design to add to this series of projects, let's see if it can be accomplished. I have one in mind to try with a 3 1/2 digit display. Only limit is top rpm readings. A 2 to 3 times per second sampling rate would serve our purposes very well. I am very interested in this add-on to the system.
John
