RE: Kaos ARF initial setup
Mine is the Kaos ARF from Tower Hobbies. I needed 2Degrees of right thrust & left the wing & stab alone. It is powered with an OS 55AX. When i had the OS 40LA in it the motor wasa at O degrees also. I use it to practice my IMAC sequences & it flies just fine for that......Gene
