Powersystem SportPlus and Futaba R6008HS
Hi Robert, planning to use the Powersystem SportPlus into a 80'span Twin Otter along with Futaba R6008HS 8ch reciever, and 10C transmitter. Though it's not that heavy plane neither has multiple servos per surface, I'd like to have rendundancy and good power distribution thru its 10 servos.
Questions are:
1) How do i get out 8 servos output thru the R6008hs; not very familiarized with this reciever.
2) Engines are glow, can i use the onboard Ignition Cutoff output to plug directly on/off Scale Lighting?
3) With the following sequence:
lipo+swith hd +PSP
lipo+swith hd
can i charge both lipos thru its balance plug using 2 different chargers?
Etham.
